98 accord lx check engine light
my check engine light came on in my 98 accord and i was gonna use the obd sensor plug to pull up the error code but the plug isnt in the bracket thats just under the drivers dash. does anyone know where it would be if its not where its supposed to be?
your car is OBD2 ,the plug to chk for codes is under dash left side but u need a scan tool ....take car to the nearest Autozone they will chk the code for u for free .......then post it here ...
The Man has got the plan...Take to AutoZone for a FREE $80.00 scan...I cant believe that someone would pay $ 300.00 and some dollars to have a O2 sensor changed,./';][ That's called Highway Robbery.
ORIGINAL: deserthonda
okay maybe i wasnt specific enough. i apologize. i know where my obd II is supposed to be located. the problem is its not where its supposed to be located. i found the bracket that its supposed to be mounted in and its not there. the reason i need to know is i can get the codes myself without auto zone by using a jumper wire in the obd II. but since the obd II is not where its supposed to be i cant do it. so does anyone know where it would be if it is not under the drivers console like its supposed to be??
ORIGINAL: sk8mistro84010
Someone probably disconnected the service check connector from the bracket and pushed it back under the dash. You may have to pull the glove box out, but I bet it's close by. It's a blue connector in most cases.
But yes I've seen the DLC be shoved out of it's bracket and stuffed somewhere else.
mickey4live
Jul 6, 2012 08:29 AM
horsebird
Dec 18, 2011 10:44 AM
78gaw
Jan 20, 2010 09:45 AM
PAY1920
Jul 1, 2007 09:58 PM
