98 accord no spark
Old Jan 14, 2013 | 03:50 PM
gm tech's Avatar
Default 98 accord no spark
my stepdaughters 98 accord (2.3 vtech) would not start.I checked it & found no spark present.I checked power at the coil & icm as listed on alldata,had power.Looks like a dist problem but not 100%.I work in a Chevrolet dealership & have very limited info on hondas.Any other tests or info would be great. Thanks in advance.
Old Jan 14, 2013 | 04:13 PM
colt1589's Avatar
Check all connections on wire harness. One time I had that issue and it turned out the crank positioning sensor wasnt connected all the way.
Old Jan 14, 2013 | 08:46 PM
In 1998 the timing sensors are connected in a couple of places. Dirty/loose/corroded connections can get ya.
- Wiring harness connection at the distributor
- Wiring connection at the CKP/TDC sensors. That connector is at the lower backside of the lower timing cover. Probably easiest to see it from underneath the car, left-front wheel area, on the edge of the engine's plastic timing cover.
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
BostonPuppyDawg
May 27, 2006 02:24 PM
Brian
Apr 5, 2006 02:44 AM
hair ball
Apr 1, 2006 11:56 PM
