98 accord v6 won't start
Old Jun 28, 2018 | 07:29 PM
paulzer's Avatar
Default 98 accord v6 won't start
I replaced the neutral safety switch but when I turn the key on the green box around the D4 lights up as well as the red box around neutral can anyone help me
Old Jun 29, 2018 | 04:21 AM
Why did you replace the neutral safety switch?
Can you still drive the vehicle? If yes, stop by a parts store and have them scan for codes. Post the codes on here.
Was the D4 and N light behaving the same way before you replaced this switch?
Old Jun 29, 2018 | 07:20 AM
paulzer's Avatar
I had intermittent problems with the switch where the car would turn over but only start in neutral but now the car does absolutely nothing and I don't think the light used to come on before
Old Jun 29, 2018 | 08:37 AM
You'll have to figure out why the new switch is causing this new issue.
Do you have a shop manual for your car to do the work? Are you good at testing electrical systems on the car?
Old Jun 29, 2018 | 09:33 AM
paulzer's Avatar
Default Was an issue before changing neutral safety switch
it wouldn't start before I changed the switch
Old Jun 29, 2018 | 10:07 AM
Where is the switch located that you replaced?
What happens with the cluster lights for Park, neutral, etc when you move the gear selector to different positions?
Old Jun 29, 2018 | 02:25 PM
paulzer's Avatar
It was the starter solonoid
Tony1M
Nov 6, 2023 08:29 PM
maso5219
Dec 5, 2015 09:09 AM
Sheri6889
Jun 17, 2015 08:19 AM
dgeorge
Nov 29, 2004 01:40 PM
