98 EX COUPE ac compressor
Old Jun 8, 2010 | 03:36 PM
jasmine82z10's Avatar
Question 98 EX COUPE ac compressor
It turns on and off every couple minutes. When it tweeks out, the car feels sluggish. Any ideas?
Old Jun 8, 2010 | 10:36 PM
Are your fans also turning off when this happens? The the a/c light stay on when this happens?
I would hook up a test light to see if you are losing power when your compressor turns off. If you have a 1-wire connection, backprobe the connector and hook on end a 12V test light on the connector. The other end, connect to a known ground (like a bolt on the valve cover).
If the light stays on when the compressor turns off, then the problem is with the clutch or the magnetic coil (or a loose/corroded ground on the compressor).
If the light turns off when the compressor cycles off, something upstream is causing the problem and you will have to work backwards starting with the relay.
Old Jun 8, 2010 | 11:48 PM
Thanks,I'll check out the fans tomorrow.And the lights do stay on when it happenes. It was working fine after I replaced the a/c controller unit Monday morning.I let my Dad charge it with a kit from O'Rilies Monday afternoon. It seemed fine this morning (Tues.)about 6ish when I drove it home. When I left tha house today around 1:30 and turned tha air on,it started to act strange. The compressor, or something under the hood seems to be running rather loud and rough.?.
ak474u
May 4, 2015 11:15 PM
Aug 2, 2006 01:35 PM
scandalus
Jul 24, 2006 01:54 AM
abelh7
Jul 7, 2006 08:02 PM
accordn2me
May 25, 2005 04:00 PM
