98 fog light install need help
Old Nov 13, 2017 | 09:29 AM
98acdriver's Avatar
Default 98 fog light install need help
Hey guys this my first time posting and need help with fog light install. Im having a problem getting the fog light bracket bolted up. Theres no tabs for the the left side of the bracket, closet to license plate. Any clue how this gets bolted up? I have a 98 lx sedan if it helps. thanks in advanced
Attached Thumbnails 98 fog light install need help-1510586692514.jpg   98 fog light install need help-1510586750929.jpg
Old Nov 13, 2017 | 10:54 AM
Welcome to HAF.
I thought I knew how to find the instruction sheet for those, but no luck at first glance. Meanwhile, I'll move this over to General Tech where it'll probably get more attention.
The New User forum is mostly for welcome & introduction posts.
Old Nov 13, 2017 | 06:03 PM
Those are aftermarket fog lights.
For the Honda accessory fog lights, they use an additional sub-bracket for the left side of the bracket.
See my post 9 #(2 in this other thread) for installation links to Honda accessory fog lights.
https://www.hondaaccordforum.com/for...install-59580/
Old Nov 13, 2017 | 06:08 PM
98acdriver's Avatar
These are oem fog lights i bought the set from honda years ago. Comes with A B C sub harnesses and all the hardware.
Old Nov 13, 2017 | 06:23 PM
Did it have the sub-brackets like in the instructions?
Old Nov 13, 2017 | 07:11 PM
98acdriver's Avatar
Ill upload pics here in a few.
Old Nov 14, 2017 | 11:58 PM
98acdriver's Avatar
Old Nov 15, 2017 | 04:55 PM
The fog lights with Honda part number 08V31-S82-100 are listed for the coupe, which is the same as the on the box in your photo.
The fog lights with Honda part number 08V31-S84-100 are listed for a sedan.
These are the OEM fog lights without the garnish, which do not require the sub-bracket. Attached are installation instructions for the fog lights without garnish. It does not require the sub-brackets.
(The previous links are for the ones with garnish; 08V31-S84-100G.)
Old Nov 15, 2017 | 07:44 PM
98acdriver's Avatar
Thanks for the info install went good just wired lights to corner lights. They look great. Now time for a retrofit.
CG5_6thGen
Jul 17, 2014 07:27 AM
kuthedude
Jun 24, 2010 10:14 AM
AFTricker
Dec 31, 2009 05:25 PM
Josh2002SiR
Jun 22, 2009 03:04 PM
ducatiff
Aug 22, 2007 04:42 PM
