98 Honda Accord drivers Window
Old Dec 3, 2013 | 04:59 PM
mack10's Avatar
Default 98 Honda Accord drivers Window
I have a 98 Honda Accord lx I just had the recall done for the ignition wiring at the dealership now my car is giving me problems. It worked for a few days then didn't start anymore did some troubleshooting and had to replace starter , cap and rotor, and ignition coil now it starts but my windows and door locks stop working i did the intermediate wiper reset and all the windows and doors work except my drivers door i replaced the control panel and it's still doing the same thing all i hear is a click but nothing is happening any help would be greatly appreciated thanks
Old Dec 3, 2013 | 05:07 PM
For the driver's door, is it both the driver's window and lock not working or is it only one of those not working?
Old Dec 3, 2013 | 05:14 PM
mack10's Avatar
Just the drivers Window dont work I can lock and unlock and roll up and down every other Window
Old Dec 3, 2013 | 05:45 PM
You can check/test at the connector for the driver’s door control unit.
1. Remove the driver’s door multiplex control unit and disconnect the 20P connector. Inspect the connector and socket terminals to make sure they are making good contact. Look for bent, loose, or corroded terminals.
2. Leave the door multiplex control unit still unplugged. You will do some test on the light blue 20P harness connector.
3. If the window is up, connect a jumper wire from terminal A11 (Red/Blu wire) to A12 (Blk wire). Connect a jumper wire from terminal A10 (Red/Yellow wire) to A1 (White/Yel wire). The window should go down ignition to ON.
If the window is down, connect a jumper wire from terminal A10 (Red/Yellow wire) to A12 (Blk wire). Connect a jumper wire from terminal A11 (Red/Blu wire) to A1 (White/Yel wire). The window should go up.
If the above procedure doesn’t do anything, you can test the driver’s window motor directly.
1. Remove door panel.
2. Disconnect the 4P connector from the window motor.
3. Test the motor by applying 12 volt battery power and ground to motor side. To lower the glass: apply power (+) to terminal 2 (yellow wire) and ground (-) to terminal 1 (red wire). To raise the glass: apply power (+) to terminal 1 (red wire) and ground (-) to terminal 2 (yellow wire).
Attached Thumbnails 98 Honda Accord drivers Window-20p-connector-terminal-numbering.jpg
Old Dec 3, 2013 | 07:26 PM
mack10's Avatar
I tried both and nothing happens just heard the click so I'm guessing the Window motor is bad
Old Dec 3, 2013 | 07:36 PM
If you tested the motor directly with 12 volt power and ground and it doesn't work, the window motor is definitely bad.
Old Dec 4, 2013 | 06:56 PM
mack10's Avatar
I went to the junk yard and got a new Window motor and it works thanks for all your help
Old Dec 4, 2013 | 07:53 PM
You're welcome. Thanks for reporting back.
SirenDeity
Sep 8, 2013 06:14 AM
Michael Bomes
Sep 9, 2012 03:12 PM
mal1981
Dec 23, 2010 07:35 AM
NALANALA
Nov 15, 2010 04:02 PM
NALANALA
Nov 5, 2007 07:46 AM
