98 ignition switch
Old Dec 15, 2011 | 08:08 AM
larrypac99's Avatar
Default 98 ignition switch
My sons 98 LX has an intermittent problem where it turns over but will not catch. Then later it will start just fine. Is the ignition switch the likely cause?
Thanks, Larry
Old Dec 15, 2011 | 09:23 AM
bigpat's Avatar
Almost A Senior Member
This sounds more like an issue with the distributor or ignitor/coil. Try searching the DIY section for more info.
Old Dec 15, 2011 | 11:50 AM
You will have to diagnose when the intermittent problem reoccurs.
Try to listen for the fuel pump to prime when you first turn the key to the II position. The fuel pump turns on for about two seconds while the check engine light does the bulb check. Get in the habit of listening for this sound. Let us know if it is missing or present when the car will not start.
Old Dec 15, 2011 | 01:33 PM
larrypac99's Avatar
Default dash lights
The dash lights are not coming on at all in any switch position. Wouldn't that be an indication of switch failure?
Old Dec 15, 2011 | 01:42 PM
I would test for 12V to the blk/yel wire going to the distributor and/or coil when the key is in the II position. If you don't have power, then I would suspect the ignition switch.
From your description, it does sound like a problem with the electrical portion of the ignition switch.
Old Dec 19, 2011 | 03:16 PM
larrypac99's Avatar
Default solved
Ordered a new switch and While waiting for the switch I discovered that it had been replaced under the recall 4k miles ago. Went to pull the wire on the old one and it came right out without pressing any tabs. Pushed it back in and it was quite hard to get it to click in but finally did. Glad I did not take everything else apart before I tried this.
Matthew Kniss
Jun 30, 2014 06:00 PM
shehadehd
Sep 20, 2012 05:20 PM
ccnicco48
Jan 16, 2008 05:16 AM
illfaver
Aug 30, 2007 03:02 PM
Fergy
Jun 22, 2006 03:41 AM
