98 starts, then shuts off
Old Mar 10, 2012 | 07:46 PM
Gbolt's Avatar
Default 98 starts, then shuts off
Hi, I have a 98 Accord LX that will not start. First, the car has been sitting for about 3 years, it had a warped head gasket and there was no compression in cylinder 3. So, we got that fixed, and changed the oil put new gas and everything.. So now the car will crank up but it will only stay on if the gas pedal is pressed all the way down, the car does not rev or anything it stays at 1. What could it possibly be? My dad says that something is probably not timed right? Or worse case the block could have been warped as well!
Old Mar 11, 2012 | 08:17 AM
The MAP and TPS connectors are the same size, did you happen to switch them when you were putting everything back together?
Old Mar 11, 2012 | 01:49 PM
bensminger2003's Avatar
run some seafoam through the intake and put some in the fresh gas as well. Seafoam is the best stuff when it comes to cleaning out the fuel system and the crap buildup in the injectors.
Is there a CEL ?!?
Old Mar 11, 2012 | 04:11 PM
Gbolt's Avatar
Well, my dad was the one who put everything back together, so I'm not sure if he did or not, I'll have to ask him. Also What are signs that they are plugged in wrong?
Old Mar 11, 2012 | 04:12 PM
Gbolt's Avatar
Yes the CEL is on actually D:
Old Mar 11, 2012 | 06:23 PM
Signs they are on wrong.....kind of what you are describing ......humor me please, nothing is going to blow up or short out if I'm wrong.
And on that other site :gdbolt95:, I asked about the main ground....g101
Old Mar 12, 2012 | 11:14 AM
Gbolt's Avatar
Well, we changed them around and the same thing still happens. Heres a vid Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Old Mar 12, 2012 | 03:42 PM
bishopb57's Avatar
Sounds like a fuel pump relay. Main relay under dash primes pump so if car starts then dies, this is a sign that relay in trunk is bad. Don't know where it is on your car, but look under access panel between carpet and forward trunk wall.
Old Mar 12, 2012 | 05:56 PM
Do you have a code reader? If the check engine light is turned on, then the PCM likely stored a code.
ughcord
Mar 9, 2019 05:19 AM
HndaOwner
Mar 1, 2014 07:38 PM
BeastlyChick2364
Jan 27, 2013 07:23 PM
9495Honda
Jan 23, 2012 07:14 PM
phatdad
Sep 5, 2011 08:19 AM
