'98 V6 Accord side engine mount
Old Dec 14, 2008 | 08:50 PM
Dan50's Avatar
Default '98 V6 Accord side engine mount
Hi guys,
While in the middle of doing a timing belt change on a V6, I am trying to remove the stubborn long bolt that goes through the side engine mount bracket on two sides, with the rubber cylindrical shaped, frame mounted "damper" in the middle. Has anybody else had trouble removing this bolt? I finally got the big bolt off the pulley, now this one is starting to annoy me. It doesn't seem like it should be giving me any trouble at all, but I really have to torque on it to move it at all. I really don't want to break it, any tips on removing it? I've been spraying it with Kroil and have turned it in and out a couple of times, so far unable to remove it.
Thanks,
Dan
Old Dec 14, 2008 | 10:09 PM
Default RE: '98 V6 Accord side engine mount
Do you have a jack supporting the engine to take the weight off of the mount?
Old Dec 15, 2008 | 03:22 PM
Dan50's Avatar
Yes, I've got a jack beneath the oil pan as advised, though the height of the engine as adjusted by the jack doesn't seem to have any relative bearing on the tightness of the bolt. In fact, the bolt is just as tight even if you remove the 2 shorter bolts that hold this mount to the engine side, as this longer bolt is on the frame side of the mount.
Thanks,
Dan
baer77
Feb 27, 2009 03:47 PM
shakinroch
Oct 1, 2008 09:39 AM
Skott83
Mar 22, 2008 09:55 AM
Skott83
Mar 21, 2008 10:02 PM
gilwood
Sep 18, 2007 09:19 AM
