99 accord 2.3 vtec hitting rev limiter at 4000 rpms?
Old Jun 20, 2011 | 08:50 PM
accord99's Avatar
Default 99 accord 2.3 vtec hitting rev limiter at 4000 rpms?
Why would it be doing this. Exactly 4000 it hits rev limiter! All gears!
Old Jun 20, 2011 | 10:08 PM
Check for stored codes.......any mod's?
Old Jun 21, 2011 | 10:38 PM
accord99's Avatar
Default i checked for codes.
There is p1259-manufacturer controlled fuel and air metering. And. A emissions code. I had no troubles till I removed the vtec spool valve, I believe it called on the back of the head. And cleaned it with Carb cleaner and replaced the gasket/o ring. Has rubber square type seal with screen in bottom of seal. Only thing I have done latley to it. Has never done this before. What does that valve solenoid do? Thanks!!
Old Jun 21, 2011 | 11:08 PM
P1259 is for a vtec malfunction. That valve uses oil pressure to activate the vtec. This is likely causing your car to run poorly. I suggest checking that you plugged it in correctly and also inspect the pins in case you bent one.
What was the other code?
phantomgrey92
Jun 16, 2013 07:14 PM
felpz420
Jun 14, 2011 07:10 PM
vdub90vw
Apr 1, 2011 07:47 PM
Driving me nuts
Dec 1, 2008 07:17 PM
dinzer
Oct 18, 2005 10:27 AM
