99 accord
Old Dec 16, 2011 | 03:32 PM
mromar007's Avatar
Default 99 accord
need 2 flush transmission fliud...whr is the plug locaded
Old Dec 16, 2011 | 03:55 PM
UhOh's Avatar
look thru this page for a new video on how to do it
though a different year, it should be pretty similar to yours
Old Dec 16, 2011 | 05:07 PM
Max Utility's Avatar
Mr Omar,
I got two videos for you:
1) One I made on a ATF change. I urge you to only use Honda ATF DW-1. 2007 Honda Accord V6 Automatic Transmission Fluid ATF Change/ Flush - Drain and Refill - YouTube
2) One from Youtube by an experienced car mechanic/tech. How To Change Honda Automatic Transmission Fluid - YouTube He does it on a older Acura from the 90s. Should be similar.
Ignore how the 2nd video says to use about "3 quarts." I urge you to measure the amount of ATF that comes out and put exactly that amount back in when putting the new fluid in. I see a lot of posts of guys doing it by the book and their tranny goes to crap, and I assume it is because of shorting the tranny by a quart or two when you do multiple drain and refills and short the tranny for what it drained out.
Old Dec 16, 2011 | 08:28 PM
Good find MaxUtility..this is helpful, thanks for finding it..
Google is your friend ..always
Old Dec 16, 2011 | 08:39 PM
Is the 99 a four cyl....if so the video is not really going to help.....
Old Dec 27, 2011 | 11:51 PM
Russianred's Avatar
Arrow
It's on the passenger side of the car, small plug with square hole in it. Look it up on Youtube - should be an easy find. Fill plug is nearby, above it.
