Replacing o2 sensor
Old Dec 26, 2011 | 12:59 PM
mkeyrouse's Avatar
Unhappy Replacing o2 sensor
I have a '91 accord, 5-spd and I'm trying to replace the o2 sensor. This is the first honda I've ever owned, so I don't know much about them. There is a heat shield that sits over the headers and directly on top of the o2 sensor. I've tried to take the shield off but it seems like the a/c hoses are keeping me from taking it off. Is there another way to get to the sensor? Something I'm not seeing? Any help would be greatly appreciated guys!
Old Dec 26, 2011 | 02:03 PM
I think there is a cutout on the shield, with an O2 socket-rent or buy one- you can remove it without removing the heat shield.
Old Dec 27, 2011 | 01:48 PM
mkeyrouse's Avatar
Thanks. Well, I got it out and replaced the o2 sensor, I also cleaned out the IAC valve. My idle seemed normal for about an hour, then it began jumping up and down again, any other ideas what it could be? I'm all out of guesses and can't afford to take it to a shop.
Old Dec 27, 2011 | 02:32 PM
Sorry, didn't know the original issue........Any stored codes? Any recent work done?
If none, IAC is good and coolant level is fine, no trapped air. Have you cleaned the air boost valve?
Old Dec 27, 2011 | 02:56 PM
Adler's Avatar
Is there an FITV on the '91?
Old Dec 27, 2011 | 11:30 PM
Russianred's Avatar
Arrow
Sounds like a vacuum leak to me, especially if the idle or RPMs are surging up and down in a rhythm.
Old Dec 28, 2011 | 12:29 AM
There are three valves. IAC, FITV, and the air boost valve. Any one can cause an air leak. This has been covered a bunch on here, so search around.
pondrun
Nov 8, 2021 09:40 AM
jaydev
Mar 26, 2012 09:18 PM
nrobinsontcnj
Feb 15, 2010 02:29 PM
kris_loehr
Dec 19, 2008 07:20 PM
bmeinert
Dec 4, 2008 09:10 AM
