99 accord to 95 accord wagon swap
Old Sep 8, 2011 | 06:14 PM
95ACCORDwagon's Avatar
Talking 99 accord to 95 accord wagon swap
ok im trying 2 different things. first, i have 2 accords one is a 95 accord wagon the other is a 99 accord v6 4 door. now my 99 has a blown tranny and the engine has something wrong with it i dont know what it is nor do i really care anymore it has 270000 miles yes i said 270,000. now i wanna know first can i swap the 5 lug piece (dont know what its called) from the 99 v6 and put it on my 95 wagon. if so will the cv joints also fit. also i want to take the entire front clip and fit it on my wagon i want to make the 95 wagon have the front of the 99. will that match is that a possibility? will the fenders match will the bumper match will the lights match will the hood match? can i do any of these with out customizing anything? please let me know anything that will help i am gonna look online at autozone.com to see if the cv's and 5 lug piece have the same parts number as the 95. thanks for your help
Old Sep 8, 2011 | 06:59 PM
I doubt that you will be able to put any body panels from the 99 to the 95.
The part that has 5 lug nuts is the wheel hub. The cast iron part is the knuckle.
I guess the question is, why do you need the 99 parts on the 95 wagon?
Old Sep 8, 2011 | 09:36 PM
i just want to do something a bit different i would like to have a 5 lug accord wagon you know like the 5 lug civics kinda make people look twice well i want the same for the wagon also i want to put 20's on it and bag it then put the body kit and lights so on and so forth. for now im just doing what i like with it but i would like to take it to car shows and see if its "show" material you know? also someone told me they have a "glass hood" for my wagon? have you ever heard of anything like that? i dont know if its glass or not but they said it was clear.
Old Sep 8, 2011 | 11:49 PM
I think you will have to do your homework before you attempt.
The easiest way to do this swap is to figure out if you can use the 95 bearing and press in a 99 hub. Then you would have to see if the splines on the 95 CV joint are the same as the 99. I have no clue if either is possible.
If you swap knuckles, then you will have more items to consider. Sounds like somewhat of a headache.
Old Sep 9, 2011 | 08:38 PM
wow it really does sound like a headache and unnecessary to spend that money so is there a 5lug swap i can do maybe a tl of the same sort or something?
Old Sep 9, 2011 | 09:58 PM
Here is a thread from our forum:
https://www.hondaaccordforum.com/for...g-5-lug-31198/
You may just be able to use your knuckle and rotor from your 99 V6. It looks like the outboard part of the CV joint is the same for your 95 wagon and the 99 V6, so the splines are the same.
Just google search: 5 lug conversion 5th gen accord for some other threads on this topic.
Old Sep 10, 2011 | 12:05 AM
THANKS PAHONDA i appreciate the info hopefully i can get this done lol
daver1100
May 8, 2014 02:41 PM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
92accordwagon
Nov 22, 2009 10:22 AM
