99 accord ex V6 humming sound
Old Jan 12, 2017 | 11:28 AM
Turtle28's Avatar
Default 99 accord ex V6 humming sound
So I just bought this accord and I noticed that there is a constant humming sound that I can only hear from inside the car. It's pretty loud and it sounds like it's coming from the engine. The hum matches rpm and also is able to be heard when in park. I've had the alternator tested and it was fine. The previous owner says the transmission has been replaced and has about 150,000 miles on it. It doesn't slip or anything. I'm at a loss. Please help.
Old Jan 12, 2017 | 12:06 PM
shipo's Avatar
Make yourself a "Redneck Stethoscope" (a short(ish) length of hose) and move it around in the engine bay until you find the noise. FYI, problems like this are virtually impossible to diagnose over the internet.
Old Jan 12, 2017 | 04:33 PM
The Toecutter's Avatar
You've got that right. To some people a hum might sound like a hum, while others might hear it as a rattle or something different. And trying to describe it in words is even harder. It could be almost anything from a solid engine mount, to the electric engine mount found on AT cars.
You might try posting a video of it and posting it to you tube.
Old Jan 12, 2017 | 04:42 PM
Turtle28's Avatar
I posted a video of the sound on YouTube already.
Old Jan 12, 2017 | 07:37 PM
As stated a "Poorman's Stethoscope" will help narrow down where the noise is coming from....alt can test good but is bearing is the issue????....PS Pump, notice any foam/bubbles in the res, like it might be sucking air, ect.
Old Jan 13, 2017 | 11:12 AM
Turtle28's Avatar
​​​​​​​No bubbles at all. Just a smooth swirl. Also no squeaking from the engine. Like I said I can only hear the sound inside the car and it sounds like it's coming from underneath the passenger floor board.
Old Jan 13, 2017 | 12:20 PM
How about an exhaust heatshield bent around & drumming against the underside of the floor??
bvh20
Jul 2, 2011 08:49 PM
bsaas
Dec 10, 2009 05:25 PM
HundaAccode
Dec 9, 2007 09:45 PM
ckebottle
Oct 11, 2006 07:49 AM
