99 Accord EX wants to stall after putting in bottle of fuel cleaner
Old Mar 7, 2012 | 08:28 AM
ghostpilot's Avatar
Default 99 Accord EX wants to stall after putting in bottle of fuel cleaner
Hello,
I just did the throttle and EGR cleaning this past weekend and the car has been running better than it has in years. Now last night I went to put gas and put a bottle of STP fuel injection cleaner along with it and this morning on my way to work the car wanted to turn off it had a very low idle, the car never turned off but the RPMS got really low. Anyone have an idea what I could have done. There are no CEL lights at all. BTW the car is a 99 EX 4 cyl AT.
Old Mar 7, 2012 | 02:58 PM
Jet sitter's Avatar
Honda recommends not to use anything in the fuel. I had a Civic that I put a cleaner in, I had to drain the tank.
Old Mar 7, 2012 | 05:43 PM
ghostpilot's Avatar
Hey Jetsetter,
Thanks for your input I will definitely not do that again. I drove the car home after work and all is well now. It seems it burned off some carbon deposits from the additive or from the throttle cleaning itself I don't really know. I have taken it around a little bit and the car is running fine. I think I may have to adjust the idle speed a little cause its around 500 after it warms up. Thanks again.
Old Mar 7, 2012 | 06:40 PM
Jet sitter's Avatar
Good to hear that your back up runing. Since you didn't drain the tank, I probably didn't have to either. Oh well, live and learn.
Old Mar 8, 2012 | 12:04 AM
After cleaning up the throttle body, look in the DIY section for a post (by me) about setting the BASE idle and forcing it to re-learn. It may be that the throttle was full of crud, and someone just "adjusted the idle" to compensate. Hondas like to have their idle-control system set up just so.
aloha_bruddah
Aug 21, 2014 01:39 PM
murphb00
Dec 16, 2010 08:40 PM
desfam5
Sep 22, 2010 11:56 PM
mjhenks
Feb 11, 2010 07:40 AM
vwl1980
May 21, 2007 07:45 PM
