99 Accord LX -- Need help finding noise
Old Apr 22, 2013 | 09:33 PM
npolite's Avatar
Default 99 Accord LX -- Need help finding noise
Hi All,
I'm stumped as to where this noise is coming from on our 99 Accord LX. It seems to be coming from directly under the A/C compressor. I have posted a link I took with my camera to see if anyone has heard this before. The issue seems to happen when I press down on the frame by the radiator.
Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Little background:
Inner Tie Rod Ends 3/2008
Ball Joints 3/2009
Bushings 1/2009
Axles were replaced in 6/2010
Upper Control Arms 8/2011
I did find a crack in the bushing for the sway bar. I tried to spray some kroil to see if that was the issue and also in the stabilizer linkage that hooks up the sway bar to the knuckle. In theory I would hope that if that was the issue it would muddle the noise a little. Not dice, the noise is still there.
It keeps sounding like the issue is just underneath the A/C compressor. Is there anything under it like a motor mount? The lower control arm bushings look good
Old Apr 22, 2013 | 10:13 PM
You just have to locate the source of the noise. Noises are hard to identify over the web. Just google ericthcarguy suspension noise for a good video on locating noises on your car.
Old Apr 23, 2013 | 04:22 PM
npolite's Avatar
Thanks for the tip. With Eric's help I was able to figure that the issue was with the radius rod bushings that go to the front frame. This is what runs directly under the A/C compressor which is where I was hearing the issue. I moved the bar back and forth and was able to replicate the noise.
Speed Demon
Aug 9, 2012 10:48 AM
exce
Apr 28, 2012 11:39 PM
aTYpicalTYrant
Mar 6, 2011 08:33 PM
Spidey677
Sep 19, 2008 10:54 AM
