'99 Accord LX, timing belt & misc
Old Nov 1, 2008 | 03:03 PM
Fontaine
Default '99 Accord LX, timing belt & misc
Love my 99 Accord. 119k miles and no problems at all.
Last visit to the dealer they said I should get the timing belt/water pump replaced and it would cost about $950. They also said there is a little coolant around a hose going into the radiator so I should replace it (another $200+) and also the plugs I had were after market (not sure why) and I should put Honda plugs on ($200+). I bought the car in '02 with $60k miles. I saw the plugs and they were loose so I see what they were talking about. The total is going to be $1500 and it include an oil change. Last maintenance package I had was the 120k package at about 101k miles and it included all the basics including draining three quarts of tranny fluid and replacing, oil change, radiator drain/refill etc.
My question is should I go ahead and pay them to do it? It costs more than $1500 but they shaved off a few dollars and threw in a rental car. I know they are still charging too much compared to local mechanics, but I really prefer to go where they keep my maintenance history and use honda parts etc. I live in a condo with no tools/space to do the work myself, otherwise I'd be doing the basic maintenance. I'm more concerned about paying so much for the timing belt, radiator hose/flush, and plug wires replacement. I'd like to keep the car for many more miles and I know the consequences of not doing the maintenance will end up costing a lot more. By the way, I drive about 6k miles/year. Ten miles round trip to work each day and light weekend driving.
Thanks guys!
Old Nov 1, 2008 | 04:54 PM
finch13's Avatar
Default RE: '99 Accord LX, timing belt & misc
First things first, look at the service record of the 120k service you had done, that usually includes the timing belt service.
A timing belt job for $950 is a tad high; a lot of people report on here that the dealer charge around $750-800 for the timing belts and water pump.
You can get much better silicone radiator (upper & lower) hoses online pretty cheap (under $50.) Maybe take it to a friends house and drain the coolant and change the hoses there? Just to save a little cash, $200 is steep for hoses.
$200 for plugs? You must have the J30 V6 engine with coil on plug type spark plugs, which typically cost $25 a piece. That's an easy $150 right there.
Our forum sponsor, TAS Auto (http://www.tasauto.com), has the Honda genuine timing belt/water pump package, probably radiator hoses and spark plugs as well. I don't have a ton of money and if I was forced to go to the dealer for service I'd find the best deal online for Honda parts and just pay the dealer the labor time.
Old Nov 1, 2008 | 06:26 PM
deserthonda's Avatar
HOW do you spell total rip off...........( the dealer you are taking the car to )
go find a shop that specializes on Hondas .. i guarantee that they as well will keep all the maintance records
As stated $ 950 is too much for a t0belt kit..
$ 200 for a hose leak,, could be just that it needs a clamp but even if it needs a radiator hose ..$ 200 if way way way too much ,, as a matter of fact if you replace the hose when you do the timing belt you don't have to pay for extra coolant , it would be just the hose $ 20 upper $ 40 lower + labor $ 50-60 dollars max
$ 200 for plugs Wow ..someone must be real hardup on making a steal over there ..even if it is coil over plugs are about $ 16-18 each,, labor no more than 60 dollars ..
my advice if you want to take it to this dealer , do as Finch advised buy the parts yourself and have the dealer install them.. But I would still advise to find an independent shop that specializes on Hondas
Old Nov 2, 2008 | 08:14 PM
Fontaine
Thanks for the replies. Very helpful.
I tried to post from memory before, but now I have the invoice in front of me. Not much info on it, but they itemized the expenses (If I get the work done):
Timing belt package: $980
Thermostat and Hoses: $356.25
Spark plug wires: $127.25
130k service: $399 (wasn't planning on this one in previous post, just the three above).
So $1500 is what they said for timing belt, therm./hoses, and wires. To break it down:
Timing belt: I will have a shop do it. I will shop around to see if I can get it cheaper, but if I have to go to the dealer, I won't sweat it since the investment is worth it.
Thermostat and hoses: Looked this up online and as deserthonda said, it's much cheaper. I wonder if they were planning on doing a full radiator flush? Still, I think I can wait on this one.
Spark plug wires: They wanted to change them because they are after market wires and they were loose (they showed me, and they were loose). I can get them online for $70 easily, but aren't bosch and ndk etc considered aftermarket as well? Every link I go to that says genuine "honda parts" always brings me to these main brands. If I need to change the wires, I can do them myself. If I remember from being younger and driving family clunkers, it's a quick job to do so, right?
I had a 120k maintenance done at 105k three years ago. I only drive 6k/year, so I think I can wait until spring for another maintenance package. Live in DC area so winters aren't terrible.
All that being said, am I right with my above actions, or do you guys suggest something different? My main concern is getting the timing belt done as soon as possible to avoid a more expensive fix if it goes.
You guys are great and I really appreciate your insights!
Old Nov 3, 2008 | 10:03 AM
If you had a major maintenance done at 105k miles, has the timing belt already been done??
Changing spark plug wiresis just as easy as you think it is. Check out a couple more places... (along with TAS)
www dot hondaautomotiveparts dot com
www dot manhonda dot com
What does that 130k service consist of exactly?
Old Nov 3, 2008 | 11:41 AM
Fontaine
ORIGINAL: JimBlake
Timing belt hasn't been done yet.
Not sure what exactly the 130k consists of. I will ask them.
I'm trying to locate honda certified mechanics (not the actual dealer) to get a better price, but can't seem to find anything with google. Any ideas how to locate them? I'm in the DC area so I would think there would be some.
Old Nov 3, 2008 | 01:24 PM
[/quote]
[/quote]
why not let your finger do the walking.. Have you checked the yellow pages ?? I am sure you will find a shop ..
top end ms
22
Nov 30, 2011 01:05 AM
generalu
Nov 9, 2010 02:25 AM
cincyaccord
Feb 14, 2010 01:30 AM
europeanforums
Feb 6, 2008 10:42 PM
Tony1M
Apr 1, 2007 05:42 PM
