'99 Accord not starting after battery cable replacement
Old Jul 13, 2013 | 11:08 AM
Steve Remich's Avatar
thanks. I did some research and my Accord was covered under a safety recall issued in 2002 for an ignition switch that wears prematurely. I bought the car used in 2010 and the original owner brought it in for recall service. I've scheduled an appointment at a local Honda dealership for them to look at it and see if it's the same problem. The guy I spoke to gave me an iffy answer whether a second repair would be covered under the safety recall too. We'll see. Is the ignition switch difficult to replace on your own? Do you have to worry about the airbag?
Old Jul 13, 2013 | 11:27 AM
Ignition switch replacement on your car is fairly easy. See Procedure B in the link:
http://www.driveaccord.net/PDF/ignition_switch.pdf
Old Jul 15, 2013 | 10:23 AM
thanks for your help. I'll let you know how it goes.
Old Jul 15, 2013 | 11:41 AM
So I wiggled the key just now and the car cut out. So I guess that could be attributed to the ignition switch. Any idea if I need to replace the lock cylinder also? Thanks again.
Old Jul 15, 2013 | 11:45 AM
Usually it is just the electrical portion of the switch; so, most likely no need to mess with the lock cylinder.
Old Jul 15, 2013 | 11:48 AM
ok. thanks.
Old Jul 15, 2013 | 11:52 AM
  #17
any thoughts on whether I should buy an OEM ignition cable or will be ok with one from AutoZone? I took it to the dealership this morning to see if it would be covered under the same recall (there was a recall for ignition switches in my model Accord in 2002, but this car was already brought in for that), but the service guy told me there would be a $60 fee just to diagnose the problem, which is about the cost of an ignition cable from Autozone. Don't know if they are the same quality though.
Old Jul 15, 2013 | 12:22 PM
  #18
None seem to last forever, so I would go w/ autozone and DIY. It's an igntion switch assembly.
Old Jul 15, 2013 | 12:25 PM
  #19
ok. Also, any opinions of whether a new auto zone brand starter or an OEM Honda starter out of an accord with 60,000 miles would be a better buy? The new starter has a limited lifetime warranty, but I'd rather not replace it all the time.
Old Jul 15, 2013 | 12:35 PM
  #20
I would go used on starter for price difference, probably $200+.
