99 Accord Wheel Bearings
Old Aug 20, 2011 | 12:21 AM
Lance Link's Avatar
Default 99 Accord Wheel Bearings
I suspect my wheel bearing is bad on my 99 accord, 145K miles, EX V6. I have 2 questions.
1. Should I do both sides even if I can isolate the noise to one side?
2. Is there any other recommended work I should do as long as I'm in there. I will be using a lift, so all four wheels will be up.
Thanks.
Old Aug 20, 2011 | 12:50 AM
You can just do the one side.
Just do inspection of other parts such as brake pads, etc. and see if anything is worn. Sometimes all you need to replace is the bad wheel bearing and be golden again.
Old Aug 20, 2011 | 01:00 AM
That bearing is pressed into the knuckle. Have you pressed out/in a bearing before?
Even before you take off the tire on the lift, turn the steering wheel until it locks. Grab the tire at 3 and 9 o'clock. Try to push and pull. There should be very little movement. Also try at 6 and 12 o'clock.
If something is loose, then try to find what is moving.
Old Aug 22, 2011 | 08:16 AM
Lance Link's Avatar
I have not, but I will have some help from an experienced person.
Thanks for the responses.
Old Aug 22, 2011 | 04:28 PM
piggylover1985's Avatar
You will have to pull the whole front knuckle off, take it to the press and press it out, make sure when you press the bearing, try to support the knuckle evenly so you don't end up bending something else because there is good amount of pressure getting the bearing out. The rear wheel bearings are a piece of cake compare to the front ones.
smilner
Jun 27, 2011 02:48 AM
Olds and Honda guy
May 24, 2011 06:24 PM
Olds and Honda guy
May 23, 2011 12:04 PM
murtazabaig
Apr 7, 2009 05:20 PM
advokat
Oct 15, 2007 10:54 PM
