99' Accord - wheelbearing?
Old Oct 1, 2008 | 07:36 PM
Tennesseestorm
Default 99' Accord - wheelbearing?
Hi all. I found a local 99' Accord LX automatic, that the seller needs a wheel bearing. It has high miles (around 245K), but he said engine was good and the transmission was good, but it made a terrible noise from the front when it was rolling. Does it sound like this could be a wheel bearing, or something with the transmission? How hard is the bearing to replace? Lastly, I can get the car for about $1500 and it looks pretty good inside out. Thanks for any tips/advice!
Old Oct 1, 2008 | 11:06 PM
noehjuan01's Avatar
Default RE: 99' Accord - wheelbearing?
if the wheelbearings are bad, the noise level will get louder as the speed increases
its acraping soundlike you have a cardboard stuck under your car
the repair can be around $200 or so
Old Oct 2, 2008 | 08:53 AM
falkore24's Avatar
A wheel bearing noise might change in pitch when turning. I wouldn't rule out a tranny issue, but I'd expect that to actually be felt rather than just making a noise. A wheel bearing will typically also make a hard clunking noise when the bad wheel goes over a bump. A tranny issue wouldn't change due to bumps.
Old Oct 2, 2008 | 04:26 PM
It could even be brakes, which would be easy to fix. Gotta take it apart to know for sure.
