'99 Accord won't rev past 2000 rpm no codes
Hello, I am beyond stumped. I have a '99 Accord 2.3 vtec automatic trans. I was driving home from work the other day, when my car started hesitating on the highway. Made it home but not without a struggle. Now when I start the engine, it will rev(in park) above the 2k threshold. But once i start driving or it warms up, I can't get the thing above 2k rpm. It will slowly accelerate, but is so bogged down that getting to 20mph is a massive struggle unless i am going downhill. I have changed the spark plug wires, distributor cap, rotor and timing belt recently. I even just changed the stupid ignition switch the other day(Thanks Honda Accord forums!)Here's the best part....NO CHECK ENGINE LIGHT! I also have no stored codes. I don't feel any misfiring and have very little other indicators as to what the problem could be. It idles fairly normally too. Any ideas? Thanks a lot.
Edit:Just swapped out the o2 sensor, but it did nothing.
Thanks for the speedy reply! The only recent work done was replacing the ignition switch and interlock a couple of weeks ago. I had thought the cat could be a possibility, but wouldn't it make a ton of noise, or at least throw a code? What's so frustrating is that i have no codes past or present. The idle fluctuates and if i hold the gas down, it fluctuates as well...even when i hold it completely steady.
Does the Check Engine Light come on when keyswitch is first turned to On, stay on for 2-3 secs, and go off?
If not, you may have either a burnt out Check Engine light, or possibly defective ECU.
ok finally got it...Poorman wins the prize! It was the cat. Got a new one for $175.00 (magnaflow) and my car runs beautifully. Let's just say the old one wasn't in the best shape, and by that, I mean it was a complete mess. Only bad part was the heat shield didn't fit around the new one.
Glad you got it and it wasn't too bad of a fix
And a BIG THANKS for coming back with the "answer" no matter what it was - too many times these threads just end without anyone ever knowing what the answer was.
Yeah, it's really frustrating trying to find a fix, only to never see a solution in a thread. It's one of the only ways to "give back" to the community here. I am not a mechanic, so any help I can give, I will.
argarcia86
Mar 17, 2013 08:28 PM
