'99 honda accord ex
Old May 29, 2011 | 08:46 AM
wnut07's Avatar
Default '99 honda accord ex
Here recently my car has been "skipping"-"jumping" while driving.could it be fuel issue or electronic??thanks
Old May 29, 2011 | 09:06 AM
There is a long list of things it could be. Going to need a little more to go on.
4 or 6 cyl, auto or manual.
The skipping/jumping, is this in the motor or trans. Under what situations does it do this. Has any recent work been done to the car. Are the regular tune up items up to date.
Old May 29, 2011 | 09:47 AM
piggylover1985's Avatar
Is the CEL on ?
Old May 29, 2011 | 10:43 AM
wnut07's Avatar
4cyl,auto.mainly does it going up hill.did a tune up lastyear.(plugs,wires,dis.cap).what is the CEL??
Old May 29, 2011 | 11:02 AM
Check Engine Light.
So under heavy load (up hill climb) the engine is skipping..
Old May 29, 2011 | 11:13 AM
At what speed ? Would it do the same thing if you're in D3 ? How is your tach when this happen ?
Old May 30, 2011 | 11:14 AM
wnut07's Avatar
will try d3.but the tach does move up and down will car "jumps'.
Old May 30, 2011 | 12:06 PM
"wnut07"- At what RPM range does this happen.
Old May 30, 2011 | 12:52 PM
wnut07's Avatar
rpm range is 2-3thou.no i havent change the fuel filter.
Old Jun 4, 2011 | 08:09 PM
wnut07's Avatar
found out that the rotor button was bad makeing the cylinders misfire.did a complete tuneup plugs,wires,ignition coil,cap and rotor button.thank you guys for the help!
