99 honda accord fuel issues
Old Sep 13, 2015 | 05:27 PM
Marv the Martin's Avatar
Default 99 honda accord fuel issues
99 honda accord...Drives one day,
Quits driving the next. Turns over but don't here the fuel pump, fuzes are good. How do I tell if fuel pump is bad/ fuel relay switch, also I been told there's a fuel pump reset button...don't believe it but if true what the location.
Old Sep 13, 2015 | 06:35 PM
Turn keyswitch to On and listen carefully for fuel pump to come on, run 3 secs, and go off.
If you're sure you don't hear this sound, next step is to check fuel pump power wire in rear trunk area for power (remember it will only be hot for 2 secs, then off so you'll need help). Fuel pump power is blk/yel wire on 5 pin connector.
If power is available for 3 secs, fuel pump or fuel pump ground fault is likely. Check for good ground on same fuel pump connector. If good, then fuel pump is problem.
If power not available at pump, Main Fuel Relay is likely fault. Under dash on driver's side, left of steering wheel. It can be tricky to access. Best bet is to separate the relay inner workings from the outer shell that is mounted on a stab post. It may be difficult!
Old Sep 14, 2015 | 05:25 PM
Default Starter
Ok starter is arking to everything nearbye, what could cause that...I've checked and cleaned the grounds.
frankenstein69
Dec 28, 2014 12:36 AM
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
Ineedhelp
Jan 22, 2012 07:29 PM
GOT BOOST
Nov 2, 2009 08:32 AM
