99 honda accord wont start
Old Jun 8, 2012 | 10:12 PM
HJCartman's Avatar
Default 99 honda accord wont start
Ok so I got out of work and went home. I decided to visit my family so I got in the car and turned it on like alwasys. When I was going to leave I tried to turn on the car and it would not crank. I put the key in the ignition and all the lights turn on the battery is good and no fuses are mest up. I push the clutch in and turn the key and it doesnt even make a sound. What can it be?? The battery, fuses and cables have been checked. Does anyone know what it could be thanks in advanced.
Old Jun 8, 2012 | 10:19 PM
1999EX's Avatar
Default not starting
check to make sure the positive connection on the starter is clean and tight...also could be something with the clutch...maybe there is a switch somewhere not working and wont allow the starter to engage
Old Jun 9, 2012 | 04:28 AM
crispin's Avatar
You need to see if you have +12 volts on the small wire at the starter when the key is turned to start.
If you have power there then you have a starter problem, if you do not have power there then you have as 1999ex mentioned a possible problem with the clutch safety switch or ignition switch.
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
EPIFEMIO
Aug 25, 2007 03:32 AM
HustlinOwl
Sep 15, 2006 03:20 AM
