99 Stalling/Erratic Idle
Old Apr 23, 2010 | 03:31 PM
deters's Avatar
Originally Posted by JimBlake
RPM dropping by 100 might be the torque converter locking up. Normal if that's it.
Honda auto trannys don't like to be "power-flushed". Drain & fill with Honda ATF.
It should only do it once per gear though right? This happens multiple times even at set speed with CC on. Is it really expensive to replace the TCC?
Old Apr 23, 2010 | 04:01 PM
There were some design flaws in the 98-02 accord automatic transmissions, that caused them to fail. This may be the start of your problem. I think that an internal bearing would fall apart and start plugging the fluid passages.
Changing the transmission fluid using Honda ATF by draining ~3 quarts, then refill, (i should double check my posts) then drive for ~100 miles, repeat for a total of 3 drain/refills should exchange most of the original fluid and possible debris. If you find a lot of metal shavings, be prepared to have the transmission replaced or rebuilt.
I would also suggest cleaning out the shift and lockup solenoids that are on the transmission housing, because they can get plugged up over time. The gaskets for those solenoids have a screen that should be cleaned too.
Old Apr 23, 2010 | 07:38 PM
Originally Posted by PAhonda
Changing the transmission fluid using Honda ATF by draining ~3 quarts, REFILLING then drive for ~100 miles, repeat ...
I hope that's what he means...
Don't drive 100 miles with the ATF 3-qt low.
Also the torque converter only locks up in 4th-gear when cruising. If you drive just the right speed it can lock / unlock / lock / over again. Kinda like you can drive at a constant (slower) speed where the transmission can't decide which gear it wants to be in.
Old Apr 23, 2010 | 09:45 PM
rpowers2002's Avatar
I posted something about my car doing this some time ago and didn't get any response. I'm guessing that I didn't make sense in the way I was describing it. Mine only does it once it is in 4th gear and is cruising between 30 and 48 mph. Kind of annoying since I had the transmission rebuilt and it wasn't doing it beforehand. BTW, my car is a 2002 with the 2.3 and has 113k miles. Most of those are highway too.. so go figure. Sadly I wish I still had my old 1992 Accord.. that thing was rock solid and the guy I sold it to still drives it.
Old Apr 25, 2010 | 07:46 PM
Hunting between gears & locking TQC are 2 "features" that cause me to only buy manual transmissions.
I probably missed your other post, sometimes if I'm gone for several days, I don't get the opportunity to wade through ALL the posts that I've missed. Sorry.
Raz93
Jul 8, 2009 07:13 AM
delgadoe
Feb 3, 2009 04:58 PM
Tai_Boi
Mar 29, 2008 01:08 AM
Planefreak
Oct 28, 2007 11:09 PM
mastar91169
May 11, 2007 10:36 AM
