Collapsed Lower Water Hose
Old Apr 22, 2010 | 07:03 PM
Accord_Ras's Avatar
Default Collapsed Lower Water Hose
Have been trying to fix an overheating problem for sometime. Car usually overheats at highway speeds or climbing hills. Today I noticed, for the first time, that the bottom hose flattens when the engine is revved.
There is no stiffener in the hose...is it made this way? The vacuum appears to be so strong, that a new hose, without stiffeners, is likely to behave the same way. What is a likely solution?
Old Apr 22, 2010 | 07:51 PM
g22cd5's Avatar
Supper Moderator
Replace that hose ASAP
Old Apr 22, 2010 | 10:32 PM
Accord_Ras's Avatar
That's the dilemma....replace it with what? The new genuine Honda hose seems to be just as flimsy as what is already on the car. The upper hose is strong and sturdy but the lower is soft and weak...is this by design? Is there some other malfunction that could be creating excessive vacuum?
Old Apr 22, 2010 | 10:56 PM
g22cd5's Avatar
Supper Moderator
Go to local auto parts store and get a replacement. I have never had a prob. with any of my hoses doing this so I'm sure your hose is just bad.
Old Apr 23, 2010 | 07:24 AM
Accord_Ras's Avatar
That's what i'm trying to do, but i'm having difficulties locating one with internal stiffeners. Recently, I have been approaching fellow accord owners and asking them about overheating problems...in every single case overheating occurs during highway driving. I'm starting to think that the higher rpm's are causing the lower hose to collapse and that this is a manufacturing/design defect.
Old Apr 23, 2010 | 09:21 AM
hondadude's Avatar
Well I'm thinking the radiator flow is poor, and the lower hose is going under Vacuum.
Also you are overheating at speeds above 20 MPH when there is good air flow over the radiator fins.
Old Apr 23, 2010 | 11:28 AM
I agree with Dude. The lower radiator hose isn't supposed to see any vacuum. That would mean the radiator is getting plugged.
Old Apr 23, 2010 | 01:58 PM
deserthonda's Avatar
http://techauto.awardspace.com/overheating.html
give this a reading......
there is no defect on honda hoses ,, you got other issues causing the problem .
Old Apr 24, 2010 | 11:08 PM
kris_loehr's Avatar
I have read the lower hose spring is only use to prevent the hose from collapsing for the way the cooling system is bled at the factory and that is why a lot of replacement hoses don’t have them.
Old Apr 25, 2010 | 07:51 PM
My lower hoses haven't even had springs inside...
95 Integra
98 Accord
03 Accord
(I haven't opened the cooling systems on the 07 Civics yet)
natoney
Sep 10, 2013 11:08 AM
quassu77
Oct 6, 2011 11:30 AM
gcleeton
Sep 10, 2010 09:19 PM
jamesejam
Sep 21, 2009 02:37 PM
Tatersaladx
Jan 19, 2009 08:59 PM
