ABS code not found
Old Dec 21, 2009 | 10:45 AM
u2nv
Default ABS code not found
Ok 2007 honda accord 4cyl automatic without VSA with 36000 miles and out of warranty. Have problem with driving car and only happens at 55mph and faster on highways and etc. and never done it in town driving, also road conditions must be wet or extremlly cold not slick just wet n icy type roads. acts as tho traction control is ingageing, keep in mind does not have vsa. and no lights come on dash. I used snap on moduis scanner and only pulled code out of abs module which was an unknown 03072. can anyone on here help out with this. it is an extremly intermittent problem, which after driving this weekend and spraying engine compartment with water and wheel wells and under car at car wash then going to drive it did not act up.PLEASE HELP
Old Dec 22, 2009 | 02:58 PM
u2nv
What gives? Nobody on here thats works in a dealership has seen this or can call honda for me as a tech and see what this code is and what problem might be? Id appreciate the help.
Old Dec 22, 2009 | 03:12 PM
I'll try to remember to look it up in my Helm book, but MY book only goes 2003-2006. If the code exists during those years, it probably means the same thing for 2007.
Old Dec 22, 2009 | 03:18 PM
mcnoople's Avatar
That code is not a valid format for a honda abs dtc. An example of a honda dtc is 42-1 for older models, but by 07 the dtc's were just 2 number codes like 42. And I did just walk myself over to the bookshelf to check the manuals. The 07 accords were not prone to problems cuz it was 5 years into the model run and they had pretty been straightened out.
Old Dec 22, 2009 | 04:42 PM
deserthonda's Avatar
couple of things my friend..
First off,, you got the code totally incorrect ,,
it is better for you as an owner to call Honda or better yet take the car to the dealer and since you car is got only 36k just barely out of warranty , if you talk to the dealer manager i am sure that they would be willing to help you,, if you get nowhere with the dealer manager ask to speak to the district Honda manager ,, get the phone # of Honda of America and express your issue with them as well ,,
93Accord2.2
Nov 7, 2013 07:10 AM
byebye2u
Dec 8, 2012 04:15 PM
tkrotchko
Mar 16, 2011 08:50 PM
madsteez
Jan 18, 2009 07:43 PM
PAhonda
Jul 21, 2008 02:51 AM
