ABS Light
Old Oct 19, 2009 | 06:11 PM
mundy007
Default ABS Light
Hello. I am new to the Forum. My fiance has a 96 Honda Accord EX . It has about 130,000 miles on the car. She just recently had the brakes, clutch, timing belt, tires, water pump, plugs and wires, and fluids replaced. Before she had that done, the ABS light was on. We have hooked a ACTRON pocketscan plus up to the car, with no codes coming back. When the brakes were done, the lines were checked, and no leaks, cracks or tears. I was hoping to get a code from the reader, but no luck. Also, sometimes when the car is cold and you start it up, the ABS light will be off. You can hear what would appear to be the ABS module making noise, cut out, and then the ABS light comes on. Any suggestions.. Start replacing modules?
Any help would be appreciated.
Old Oct 20, 2009 | 06:55 AM
Jumper the SCS connector (the old-school way to read codes) & look for the ABS lamp flashing. It goes like this...
Long flash & long pause - that's not part of the code yet.
short flashes - 1st digit of 1st code
short pause
short flashes - 2nd digit of 1st code
long pause
short flashes - 1st digit of 2nd code
short pause
short flashes - 2nd digit of 2nd code
etc...
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Old Oct 21, 2009 | 12:33 AM
deserthonda's Avatar
make sure that the abs reservoir is full,,,,,,,,,,,,,,94-97 had issues with leaky modulator/accumulators .
if it is full,, bleed the abs system ......
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
anthonyj89
Sep 24, 2008 10:20 PM
shinobi16
May 18, 2005 08:21 AM
