ABS light comes on immediately
Old May 18, 2024 | 09:48 AM
finndago's Avatar
Default ABS light comes on immediately
Hey guys, 1997 Honda Accord EX has ABS light on. Comes on immediately after dash lights come on and stays on. I read and watched some vids on purging and bleeding the ABS unit, and tried it. Theres no pressure whatsoever to push fluid or brake fluid into a bottle. Ive got the relay out and jumpered the 2 pins and the motor runs, but its not purging brake fluid. Could it be that mechanical gizmo that has the bullet shaped metal pieces is stuck? I'm at a loss, but ABS isnt leaking anything. BTW, I tried getting the codes from the blue 2 pin jumper under the glove box, but it didnt work, just blinked couple times and stopped. Thanks for any help you can recommend.
Old May 20, 2024 | 04:28 PM
Moved your post to the forum where you'll get replies.
ABS codes have two numbers, like 3-4. The ABS light will turn on for two seconds then pause for two seconds. The you'll havea a series of flashes, a 1 second pause, then flash a second set of flashes. The light will pause for 5 seconds, then flash another coder (or the same code if you only have one code). Count the number flashes in each set to get the ABS code.
Old May 21, 2024 | 10:37 AM
finndago's Avatar
I did the jumper on the blue connector under the dash. I couldnt get it to give me any codes. I tried several times, but I'll give it a go again.Thank you for the answer though.
finndago
May 18, 2024 09:41 AM
camman
Apr 3, 2013 08:49 AM
Jcaleno
Mar 17, 2012 05:47 PM
hondajuice
Jan 14, 2010 06:30 PM
