ABS Red Dashboard Light
I have observed about 5 or 6 times in the past 3 weeks the ABS malfunction light staying on after a start up. If I shut the engine off it and restart the car the ABS system properly sequences until the dashboard light goes off. This is on a 2005 accord coupe LX 4 cyl with 123,000+ miles. I assume perhaps a sensor is malfunctioning or something is not fully operating through sequence on engine start up. I really don't want to pump a lot of money to repair this, but one day I am going to have to sell this car and I don't want to have a problem doing so. Fortunately, or not, there is no vehicle inspection law in Florida, so no immediate problem. Anyone have any ideas on what is going on here? Thanks and I appreciate any feedback in novice language.
To diagnose, the ABS code from ABS controller must be accessed. I check my 2003-2007 Accord manual and it does not indicate a "diy" method of extracting codes (two digit codes 11-81). It requires Honda Diagnostic System (HDS) which only dealer or honda-specific shop may have.
That said, others have extracted SRS codes w/ following procedure which may also work for ABS. See following link. ABS light should flash the code.
DIY: SRS Codes and reading them. - Club RSX Message Board
The SRS procedure may not exactly match ABS procedure. ABS always resets on restart, however codes may still be stored.
Only trial&error will tell if ABS will flash codes. Otherwise you'll need to find someone w/ a HDS compatible tool.
93Accord2.2
Nov 7, 2013 07:10 AM
