ABS Red Dashboard Light
Old Aug 16, 2013 | 04:10 PM
fvansan's Avatar
Default ABS Red Dashboard Light
I have observed about 5 or 6 times in the past 3 weeks the ABS malfunction light staying on after a start up. If I shut the engine off it and restart the car the ABS system properly sequences until the dashboard light goes off. This is on a 2005 accord coupe LX 4 cyl with 123,000+ miles. I assume perhaps a sensor is malfunctioning or something is not fully operating through sequence on engine start up. I really don't want to pump a lot of money to repair this, but one day I am going to have to sell this car and I don't want to have a problem doing so. Fortunately, or not, there is no vehicle inspection law in Florida, so no immediate problem. Anyone have any ideas on what is going on here? Thanks and I appreciate any feedback in novice language.
Old Aug 17, 2013 | 03:47 AM
fvansan's Avatar
anyone??
Old Aug 17, 2013 | 08:26 AM
To diagnose, the ABS code from ABS controller must be accessed. I check my 2003-2007 Accord manual and it does not indicate a "diy" method of extracting codes (two digit codes 11-81). It requires Honda Diagnostic System (HDS) which only dealer or honda-specific shop may have.
That said, others have extracted SRS codes w/ following procedure which may also work for ABS. See following link. ABS light should flash the code.
DIY: SRS Codes and reading them. - Club RSX Message Board
Old Aug 17, 2013 | 10:36 AM
fvansan's Avatar
Thanks, but the light doesn't flash/blink. Just stays on a solid lit ABS icon. Once I restart engine, it goes off normally.
Old Aug 17, 2013 | 10:56 AM
The SRS procedure may not exactly match ABS procedure. ABS always resets on restart, however codes may still be stored.
Only trial&error will tell if ABS will flash codes. Otherwise you'll need to find someone w/ a HDS compatible tool.
818coupe
Jul 23, 2019 02:36 PM
SamD
Jan 18, 2017 08:22 AM
93Accord2.2
Nov 7, 2013 07:10 AM
jron
Jan 26, 2013 09:09 AM
emgomez
Jun 21, 2008 01:48 AM
