AC
Old Aug 30, 2010 | 02:39 AM
Are you planning on recharging the system on your own?
If so, I would consider replacing all the o-rings in the system and use a lubricant like Nylog or an equivalent.
You should also consider replacing the receiver/drier, because your system has been open to air.
Make sure that you pull a vacuum on the system and the a/c system and make sure it holds the vacuum (no leaks). Then charge the system.
Old Aug 30, 2010 | 12:50 PM
C3paco's Avatar
Thanks for the tip. I will do that seeing that the condenser will be new.I will have a shop do it for me do to the fact that i have no vacume ill get them to recharge the sistem.
Old Aug 30, 2010 | 07:59 PM
And I want to say "Thank you" for letting us know what was found and where you are going, too many times we never know the end of the story. Which menas I/we never really know if the advise worked....so please let us know if it all works out and good luck.
