AC auto light and recir light not coming on 2008 honda accord exl v6
Old Sep 6, 2013 | 05:10 PM
Winston Hart's Avatar
Default AC auto light and recir light not coming on 2008 honda accord exl v6
Hi All,
New to the forum just had some work done on AC unit and now my auto light doesn't come on but the AC does and the recirculating button light is out also and the air definitely is not recirculating. Need help
Old Sep 6, 2013 | 05:47 PM
What work did you have done on the car?
See if there are any Diagnostic Trouble Codes (DTCs).
1. Turn the ignition switch to LOCK (0), and then to ON (III).
2. Press and hold the OFF button, then within 10 seconds press and release the REAR WINDOW DEFOGGER/MIRROR DEFOGGER button five times. Release the OFF button; then the self-diagnostic begins.
· The blower motor will run at various speeds regardless of what the panel is displaying.
· If there is a problem with the system, the temperature indicator flashes 88, and the A/C ON indicator or the AUTO indicator (or both) also flashes. Segments in the temperature indicator then indicate which DTCs are present.
· If there is more than one DTC, they are displayed one at a time in sequence followed by a pause (all the display indicator segments illuminate) between the DTCs.
· If there are no problems detected, the segments will not illuminate, and the system will appear to be turned off.
3. Turn the ignition switch to LOCK (0) to cancel the self-diagnostic function. After completing repair work, run the self-diagnostic again to make sure there are no more DTCs.
Attached Thumbnails AC auto light and recir light not coming on 2008 honda accord exl v6-checking-dtcs.jpg
Old Sep 7, 2013 | 08:50 AM
It was a change out of all the major ac parts, compressor,condensor, evaporator, dryer only the lines weren't changed.
Old Sep 7, 2013 | 09:05 AM
Tried the diagnostic test nothing was displayed. However the recirculation light came on after the test. When I touched the button it went off and hasn't come back on.
Old Sep 7, 2013 | 10:15 AM
There's a possibility the 7-P GRN connector for the recirculation control motor was not securely re-connected after the evaporator was replaced.
The recirculation control motor is located behind the glove box; and the 7-P Grn connector should be located behind the motor.
If the recirculation control motor was not working, that may be the reason the auto indicator light may not be on; as the climate control unit cannot turn on recirculation mode for maximum coolness.
Old Sep 7, 2013 | 12:15 PM
Thanks so much. Is this something I should be able to check or a job for my mechanic.
Old Sep 7, 2013 | 12:22 PM
If the 6 is like the 4 cyl's.....if you remove the glove box you should be able to get to the motor and connector.
EDIT: here is a pic from the 4 cyl cars....should be the same on the 6 cyl's
Attached Thumbnails AC auto light and recir light not coming on 2008 honda accord exl v6-8th-gen-recirculation-control-motor.jpg
Old Sep 7, 2013 | 12:32 PM
Thanks 212 will take a look
Mikebike125
Jun 30, 2015 05:26 AM
TonyC2012
Aug 4, 2012 12:05 PM
annarborcoupe
Dec 16, 2010 07:25 PM
redondoredhonda
Aug 21, 2010 05:30 PM
dking99
May 20, 2009 09:09 PM
