AC problem On 2000 accord v4 2.3
Old May 31, 2012 | 09:16 PM
sid's Avatar
sid
Post AC problem On 2000 accord v4 2.3
my car ac is not working took it to the regular shop there was a leak he fix it was dryer rings after he pressure test vacuum and fill the gass. every thing is running fine except no cold air at all. heat and cold control button also seem working. he told me there is some thing in my dashboard that might b a problem(i fogot the part name) but he told me take it to Honda for test .
Any one have any clue what i can do by myself to make it running
thanks
Old May 31, 2012 | 09:24 PM
Your car is an I4.
Does any temperature air blow out of the vents? Does it work on all speeds?
Does your radio look like the picture below?
Old May 31, 2012 | 09:44 PM
sid's Avatar
sid
ye air comes out and it works on all speeds temp control also work if i put on heat it give me heat but when put on cold gets air but not cold
no it dost not look like its different one here is the link for that
2000 Honda Accord EX Sedan Quartz Dashboard Photo #51263297 | GTcarlot.com
Old May 31, 2012 | 09:53 PM
You can try to find the trouble code on your heater control. Here is the information.
Turn ignition switch to II position.
Turn the fan switch to off and the recirculation switch to Recirculate (recirculation indicator comes on).
Press and hold the recirculation control switch to Fresh (recirculation switch goes off). Continue to hold the switch untl the recirculation indicator comes on for 2 seconds, then it will blink the Diagnostic Trouble Code (DTC) to indicate a faulty component.
Let us know what you find.
Old May 31, 2012 | 10:07 PM
sid's Avatar
sid
yes it come on for 2 seconds but where it blink the code
Old May 31, 2012 | 10:11 PM
The recirculation light will flash the code after it comes on for two seconds. I'm not sure if you have to hold the recirculate button the whole time or not. Try it both ways.
Old May 31, 2012 | 10:19 PM
sid's Avatar
sid
i did didt get any thing little confused where to look the code its just a simple bulb that light up that button
Old May 31, 2012 | 10:32 PM
That's manual climate control, not auto-climate-control. I don't think that system can store error codes.
Check to see whether the water valve is operating...
1) Open the hood, follow the heater hoses to the firewall. One of them should have a cable-operated valve.
2) Get a helper to sit in the car. Turn the key ON - not necessary to actually start the engine. Turn the temperature **** back & forth - hot & cold.
3) You should see the cable moving on that valve. Let us know before we go farther with instructions.
Old May 31, 2012 | 10:35 PM
After that bulb lights up for two seconds and turns off it would start blinking. One blink = code 1, etc.
kellysa111
May 1, 2009 08:35 AM
friskoesupastar
Jan 24, 2009 03:46 PM
kissbally78
Dec 25, 2008 07:36 AM
XYKD
Dec 17, 2008 11:30 AM
mlaccord
Jul 31, 2006 12:22 AM
