Starting Problem on 2000 Accord Coupe
Old Jul 30, 2006 | 02:35 PM
mlaccord's Avatar
Default Starting Problem on 2000 Accord Coupe
I can not get my car started, when I turn the key I hear a rapid clicking noise (sorta like a woodpecker). I don't think it's the battery because my lights and radio works. The noise sounds like it's coming from the starter, but I really don't know that much about cars. Any help would be much appreciated.
Thanks.
Old Jul 30, 2006 | 02:40 PM
deserthonda's Avatar
Default RE: Starting Problem on 2000 Accord Coupe
ORIGINAL: mlaccord
Thanks.
it definately could be the battery,that's my first guess, , it takes a LOT more to start the car than to turn the lites on...........also chk the battery cables make sure they are clean and tight,
have the battery and charge system checked out ...........if all is ok, with batteryand cables ,,,,,,,,,most likely you got a bad starter .
Old Jul 30, 2006 | 03:37 PM
mlaccord's Avatar
You were absolutely correct. Thank you.
Old Jul 30, 2006 | 03:44 PM
ORIGINAL: mlaccord
was it a bad battery ?? or the cables ??
Old Jul 30, 2006 | 06:52 PM
mlaccord's Avatar
Battery. Thanks again.
Old Jul 31, 2006 | 12:22 AM
mbo1985's Avatar
when you hear that woodpecker sound it means the battery doesn't have enough juice to crank the motor, but enough to run the lights, radio, etc..
osama
Mar 7, 2013 06:40 AM
itsfrito
Dec 12, 2012 07:15 AM
jlabbe212
Jun 21, 2011 08:58 PM
Railey
Feb 18, 2011 02:42 AM
atcampbell2
Jan 4, 2011 12:09 PM
