starting problem in honda accord 2000 v6
Old Mar 5, 2013 | 09:20 PM
osama's Avatar
Default starting problem in honda accord 2000 v6
can anybody tell me what exactly the problem , when i drive lot and park for 10 -15 minutes and start the engine the RPM starts jamb between 0 and 1 ????
That is exactly what happens in video
Old Mar 5, 2013 | 10:17 PM
This has nothing to do with fuel. Either the ignition switch, starter, or the battery.
Call your local honda dealership and find out if the ignition switch recall was ever done on your car.
See if jump starting the battery will get the car to start.
Old Mar 6, 2013 | 07:28 PM
Just me but some of the v6 accords in this gen had/have a heat soak issue....vapor lock.
And again just me but the "winter blend" of gas seems to make the issue worse.
Old Mar 6, 2013 | 07:45 PM
osama's Avatar
it's OK but this car is no problem all the time just after stop in park at 10 -15 minute either once week .
Old Mar 7, 2013 | 06:40 AM
Don't know where osama is located, but if that 10-15 minutes is idling the engine then vapor lock makes even more sense.
Winter-blend fuel makes it worse. It has a higher vapor-pressure to make it easier to vaporize when the engine is cold. That also makes it easier to vaporize in the fuel lines in a hot engine-compartment.
gmattutorsam
Mar 28, 2013 04:58 PM
itsfrito
Dec 12, 2012 07:15 AM
Railey
Feb 18, 2011 02:42 AM
atcampbell2
Jan 4, 2011 12:09 PM
mlaccord
Jul 31, 2006 12:22 AM
