AC Stator needs replacing???
Old Sep 21, 2011 | 08:58 PM
gar8328's Avatar
Default AC Stator needs replacing???
I was told that the stator on my AC compressor needs to replaced. What is a "stator" and how much can I expect to pay to have it replaced? Is that something I can do myself? Thanks for any help! I have a 2004 Honda Accord LX 4 cyl automatic. It has 160k miles.
Old Sep 22, 2011 | 06:57 PM
Others would call that the ac clutch coil, #12 in pic.
Some models you can change the ac clutch without removing the compressor-which means you do not have to "open" the system and then re-charge, I don't know for sure on your 04.
Can you do it, I can't answer that? You will need to remove the entire ac clutch to get to the coild and then re-install everything.
Old Sep 22, 2011 | 07:08 PM
Replace the clutch coil w/o discharging may be possible, but I haven't heard from anyone who has done this job. I've looked at compressor position and it looks doubtful.
A quick check of Honda shop manual provides no encouragement that repair in place is possible.
dhg2496
Apr 19, 2008 08:41 PM
mikes
Oct 23, 2005 10:34 PM
ncpmedic
Oct 17, 2005 02:48 PM
deli6388
Aug 8, 2005 11:27 PM
RoX
Jun 24, 2005 05:47 PM
