AC Valve Core Leaking
Old Aug 5, 2012 | 02:53 PM
curtie94's Avatar
Default AC Valve Core Leaking
Ok so I filled my ac about a month ago after replacing the condensor and compressor, now It stopped working again. The compressor kicks on and runs, but I get no cold air out of the vents.
My pressures are:
Low: 5psi
High: 95psi
I know these are not good and indicate a leak. The only place that I know I had a small leak was the low pressure valve core. Could it leak out in one month like that?
Old Aug 5, 2012 | 03:44 PM
It's possible the leak is from schrader vavle, but unlikely if the valve caps were in place and tight.
Look for oily/dirty spots on condensor face, around connections, hose crimps, and around rotation plane of compressor clutch.
If you find a dirty ring around the compressor clutch rotation plane, a leaking compressor shaft seal is the problem. It can be replaced, but will require compressor removal. If you find this I can give some tips on sourcing the seal and installation.
Also, the expansion valve orings are prone to leak w/ age. Replacement requires pulling the evaporator box, a fairly large task, but not too hard on most Accords.
Put your Accord description in your signature line.
Old Aug 5, 2012 | 04:17 PM
phatboyslim2012's Avatar
if the stem is leaking autozone has a valve stem repair kit for $3.99
Old Aug 5, 2012 | 04:29 PM
Was a vacuum leak check performed when vacuuming for charging? This should have disclosed a leak.
Check all connections that were re-made. Soap solution will work as long as there's internal pressure above ambient.
Old Aug 5, 2012 | 05:05 PM
curtie94's Avatar
Oh I'm sorry its a 1991 Honda Accord. I replaced all of the orings through the system. I also added some uv dye and nothing lights up.
I did NOT have caps on the schrader valves, would that be the issue? Should I just refill and put caps on.
I pulled a vacuum when I filled and I had no drop in vacuum for an hour when I let it sit with the gauges on.
Old Aug 5, 2012 | 06:48 PM
Check the compressor clutch rotation plane carefully. I've seen a one-way leak on these shaft seals. Other than that, the leak must have developed post-repair, not unheard of but unusual. Solution in any case is to find the leak.
Fear_The_Marshmallow
Nov 7, 2007 11:45 AM
playaman
Apr 2, 2007 07:38 PM
Pauls95
Feb 7, 2007 06:56 PM
bobnorth
Oct 23, 2006 09:22 PM
nok1
Apr 30, 2005 04:21 PM
