acceleration
Old Nov 25, 2017 | 04:12 PM
fljmruiz's Avatar
Arrow acceleration
my honda accord 1997 had acceleration problem
engine f22b2
no codes
crank right up
new egr
fuel pump ok
new timing belt
new plugs
new distributor
new fuel filter
the problem after the car crank engine on "idle
' press gas pedal and.. engine
died.. I adjust the throttle cables... I try three intake throttle so far the same problem..
Old Nov 25, 2017 | 05:54 PM
Do you have a scanner that can read live data? You said the fuel pump is ok. How did you test it?
Old Nov 26, 2017 | 09:06 AM
Was there anything done to the car before this started happening?
Old Nov 27, 2017 | 01:24 PM
If you adjusted the throttle cables trying to deal with this, maybe first you should get everything back the way it's supposed to be set up. If the throttle cables aren't slack, or if the throttle stop screw has been adjusted, that might send you on a wild-goose-chase trying to diagnose it.
https://www.hondaaccordforum.com/for...e-speed-38734/
Pat61
Apr 20, 2012 03:21 PM
Apr 25, 2006 03:14 AM
santiagueƱo
Jan 8, 2006 05:11 PM
solo1001
Jun 7, 2005 12:20 AM
My wifes honda
May 24, 2005 02:59 AM
