accelerator lube?
Old May 17, 2007 | 10:15 AM
spoon059
Default accelerator lube?
I have a 98 Honda Accord with just over 83,000 miles. I have noticed that sometimes the accelerator pedal gets stuck (resists opening) accerawhen I attempt to accelerate. It isn't much, but I get a slight resistance when I push, then I feel it "pop" through whatever obstruction it is, and the pedal is fine. It usually only happens the first time I push the accelerator. Is there somewhere that I can clean and re-lube to prevent this problem?
Old May 18, 2007 | 12:54 AM
deserthonda's Avatar
Default RE: accelerator lube?
you need to clean the trottle body , get some carb cleaner and clean the inside of the trottle body where the throttle plate is , also clean the outer linkages ,
nicademus
Aug 20, 2014 05:19 PM
Wicked Pete
Jun 20, 2010 09:49 PM
19962door
Dec 17, 2009 08:32 PM
19Accord97
Mar 21, 2008 11:29 AM
tiger94
Jul 5, 2006 01:04 PM
