Accessory port quick fix?
Old Mar 30, 2014 | 10:42 PM
ccookie66's Avatar
Default Accessory port quick fix?
Hello. On my accessory port/cigerate lighter in my Accord, it only works with some plugs. For example, my phone charger works fine, but the pizza delivery sign that plugs into the accessory port, only works if I press down hard and hold it into the port. I am thinking the end isn't making a good connection. So, if I take so tin foil, and put it in the accessory port, would that help make a better connection? I don't know how these accessory ports work exactly, and I don't want to short something put, so any help would be awesome! Thanks!
Old Mar 31, 2014 | 10:34 AM
Turtlehead's Avatar
You can short it if the foil contacts the pos and neg. It sounds to me like the light connector is bad. You can also try pushing in the light connector and give it a slight twist to see if it gives a better connection.
This was a weird post, but hey, we all have to keep working, right?
5.0stang
Apr 28, 2013 11:09 PM
thatchrisguy122
Jun 29, 2011 06:07 PM
lakerat
Dec 16, 2010 08:17 AM
get'er go'in
May 4, 2010 12:33 PM
mbo1985
Nov 26, 2006 02:42 PM
