accessory toggle switch mounting area for 2001 Accord
Old May 22, 2011 | 09:25 PM
albertaaccord's Avatar
Default accessory toggle switch mounting area for 2001 Accord
i have purchased a new head unit, and it comes with a safty feauture that has a wire connecting to the emergency brake so you can not view video when it is not engaged. I was wondering where would be the easiest place to mount the toggle switch i will use to fake apply the emergency brake. i was thinking right beside the emergency brake, or under the steering column. also does anyone know the best way to remove that trim piece.
thanks in advanced
Attached Thumbnails accessory toggle switch mounting area for 2001 Accord-imag0035.jpg
Old May 22, 2011 | 09:49 PM
crispin's Avatar
Why not just ground it out all the time?
That is how I have my Pioneer Avic-Z2 set-up.
Why use a toggle switch?
Old May 23, 2011 | 01:45 AM
would that work if the head unit requires a specific sequence when setting the emergency brake to view the video?
Old May 24, 2011 | 08:13 AM
crispin's Avatar
No it will not.
You should do some research on-line about how to bypass your radio.
For me I had to ground out 2 wires and then I updated the unit using some software I got online for free.
Old May 24, 2011 | 12:30 PM
Ok ill look in to that, thanks
95Coupe_360
Jul 19, 2013 12:31 AM
accordlover9696
Oct 14, 2012 08:12 PM
elgwedoloco
West
11
Dec 13, 2010 03:01 PM
rminor205
Mar 14, 2007 07:44 PM
adbraz
Jul 6, 2005 02:37 PM
