accord 1995 - climate control problem.
Old Aug 22, 2015 | 06:04 PM
tincho's Avatar
Default accord 1995 - climate control problem.
Hi, since a year or more, the climate control of my accord coupe ex 95 started working funny. First the temperature raises up and then the commands doesnt respond anymore.
I tryed to find a replacement on ebay.com but never find the piece.
I donīt know what to do, all the solutions I browsed are for a different model.
I am sharing some pictures because the unit it is not very common.
Any help it is really appreciated.
Thanks,
Martin
Attached Thumbnails accord 1995 - climate control problem.-img-20150213-wa0000.jpg   accord 1995 - climate control problem.-img-20150213-wa0002.jpg   accord 1995 - climate control problem.-img-20150213-wa0001.jpg
Old Aug 22, 2015 | 06:57 PM
Do you hear clicking/popping sounds from under the dash? The air mix motors are known weak points, and when defective it is difficult to set air temp. Easy job on most cars to replace air mix motor.
I could not find ATC controls in any 4-cyl Honda shop manuals I had for years 1995. Is this perhaps a V6 engine?
Old Aug 22, 2015 | 07:20 PM
tincho's Avatar
Thanks texas honda for your answer.
I do hear clicking/popping sounds from under the dash. Where do I find the air mix motors?
The car is 2.2 vtec, but the ATC control I dont know why it is the same to an accord k7 2.7 v6. In Uruguay (where I live) some of them are with ATC controls.
Old Aug 22, 2015 | 08:17 PM
Use the clicking/popping sound to locate the motor/s. I don't have a manual w/ the air mix motor/s (may be two if driver/pax temps can be set differently).
I checked Majestic Honda online parts for ATC on V6 and 4-cyl and found no ATC controls. Must be Uraguay special.
Old Aug 22, 2015 | 08:34 PM
tincho's Avatar
Thanks Texas,
Its a rare part. The part #is 79600-sv4-c42 - denshingiken (brand).
I have been searching in ebay for the last year an a half and never found one.
I will disconnect the air mix motors and check again the module.
Thanks!!!
Martin
Old Aug 23, 2015 | 09:10 AM
When I had this problem on MDX, I locked (jammed the link bar against nearby part) the air mix door in cold position for max cooling until I got a replacement.
If you are handy, you may be able to repair the air mix motor. See attached video link. Lexus motor is very simiar to Honda. I tried but dropped and lost one tiny gear, and had to buy a new part.
deathman
Aug 25, 2024 12:34 PM
Rachel Mulhall
Sep 23, 2022 07:30 AM
Pancho
Jun 4, 2012 06:53 PM
john wilks
Sep 13, 2009 02:51 PM
greenbean
Sep 21, 2007 03:14 PM
