Accord 2003 k20 engine tapping noise
Old Oct 27, 2016 | 03:10 PM
kwakers's Avatar
Default Accord 2003 k20 engine tapping noise
I've already asked this question some time ago but I thought I'd try again. My k20 engine with just over 100k on the clock (miles) has a slight tapping noise mainly when it's cold. It's very slightly tapping when it's warm. I have replaced a faulty exhaust camshaft (one lobe was breaking up) I also changed the chain and tensioner as a matter of course. The valve clearances are correct the engine runs very well and it doesn't use any oil. It was suggested it could be piston slap as the tapping noise is in time with the piston stroke. The tapping us pronounced when the engine is slightly under load. Any thoughts or ideas would be greatly appreciated.
Old Oct 27, 2016 | 06:55 PM
Noises are tough to figure out over the web. I've read that valves can make some tapping noise when cold, then the noise reduces when the engine warms up.
Not sure if there is much you can do without tearing apart the engine to verify piston slap.
kwakers
Oct 26, 2016 02:46 PM
kwakers
Sep 9, 2015 10:47 AM
kwakers
Aug 16, 2015 01:18 PM
Derekhhh
Oct 13, 2013 03:14 PM
brucehjr
Apr 18, 2010 07:01 PM
