Accord 3.0 instruments dead
Old Nov 21, 2010 | 09:51 AM
Edward's Avatar
Default Accord 3.0 instruments dead
Hi
I drive a 3.0 Accord V6 1999. I have just gone to use the car and the instruments have stopped working, that is the speedo, tacho,temp and fuel guages. Everything else works. All the fuses are fine and I have wobbled all the relays to try to make sure their connections are good.
Does anyone have any ideas what is wrong please?
Regards
Edward
Old Nov 21, 2010 | 11:31 AM
Did you check the under-dash fuses?
On other models, the No 1 fuse (10A) in underdash fuse box supplies power to virtually entire panel.
Old Nov 21, 2010 | 12:01 PM
Edward's Avatar
Thanks Texas
I only looked under the hood. I am in the Isle of Man in the British Isles so it's dark now, I'll check in the morning.
Regards
Edward
Old Nov 25, 2010 | 12:04 PM
Edward's Avatar
Problem solved. I could not find a solution so I punched the dasboard hard just above the instruments and they started to work again.
Old Nov 25, 2010 | 04:22 PM
Well,,,,you won't find that procedure in the shop manuals.....if it comes back I guess you know there is some sort of loose connection.
Old Nov 25, 2010 | 04:37 PM
My guess would be a cracked solder joint on the circuit board of the panel. It could also be a faulty harness or connector.
tnlouielv
West
Sep 20, 2015 10:09 AM
ProZak512
Dec 23, 2012 09:08 AM
Jethead102
Nov 28, 2012 12:38 AM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
