Accord 96 Ex starter replacement
Old Apr 27, 2009 | 06:56 PM
niahuynh's Avatar
Unhappy Accord 96 Ex starter replacement
Hello guys, I'm new to the forum and been searching for DIY on how to replace the starter on my car. I couldn't seem to find anything yet so I decide to ask question here. Thank You in advance for the help.
Old Apr 27, 2009 | 07:20 PM
hondadude's Avatar
First thing is to have the radio security code on hand. [if you have one]
Then dis-connect the battery negative cable, on the starter there is a slip on solenoid connection and a POSITIVE battery lead that has a 12mm nut securing it.
Then there are 2-14mm bolts that hold the starter to the torque convertor housing.
The bottom bolt can be tough to get to...I think a 6" extension with a 14mm deepwell socket will work.
If the starter is just clicking sometimes, the contacts might be worn down.
The cost of replacement contacts is way less than a new starter and are easy to replace in the 'ND' starters.
Here is a pic&link of the starter contacts in an 'ND' starter;
http://img142.imageshack.us/img142/6...contactnf2.jpg
Old Apr 27, 2009 | 07:27 PM
niahuynh's Avatar
Thank You Hondadude for the information. I'll check it out tonight.
56belair
Aug 12, 2015 06:10 PM
honda409
Feb 5, 2010 10:42 AM
seattlehawk
Jun 6, 2009 05:04 PM
mdjbhouse
Dec 28, 2006 08:31 PM
mcrisost1999
Jun 3, 2005 12:45 AM
