Accord coupe 98 4l, 2 doors, Vtec problem.
Old Apr 23, 2013 | 09:56 AM
wiolfredocoupe's Avatar
Thumbs up Accord coupe 98 4l, 2 doors, Vtec problem.
Accord 98 coupe, 4l, 2 doors. CODE V-TEC MALFUNCTION. Vtec cleaned and seal and filter changed, also thermostat housing seals. More power but no run after 400rpm. Some people say a bolt in side valve cover 14mm. I do not know if in cover or above valve. Other mension timing belt, but it is new. I may say oil war spreaded everywhere after spark tube seal were placed wrong way. It was fixed. What else.
Also I bought the knock sensor, but the one i found above oil filter is diferent (smaller), although use the same tool to unsscrew out. All knock sensor original and replacement are the same I bought. May I have a diagram for a corrrect location. Images will be perfect.
Thanks
Wil
Old Apr 24, 2013 | 07:11 PM
What is/was the actual code?
Can we assume the oil level, change it proper/up to date.
daver1100
May 30, 2014 08:00 AM
bigs
Dec 10, 2012 01:41 AM
czr
Mar 9, 2012 07:02 PM
Amtrak288
Aug 31, 2011 08:18 PM
leckey73
Jun 16, 2006 01:27 PM
