shift linkage removal
Old Nov 29, 2007 | 08:50 AM
imjrk's Avatar
Default shift linkage removal
Have a '96 Accord VTEC, automatic. Need to know how to disconnect the shift cable from the trans. Have the cover off the trans, but cannot figure out how to remove the cable. Thanks
Old Nov 29, 2007 | 11:54 AM
deserthonda's Avatar
Default RE: shift linkage removal
remove the 10mm bolt that hold the lever into the tranny , but first you need to unlock the lock tab,, get a small scredriver and a hammer, tap on the little tab so you can get a 10mm socket into the bolt . remove the bolt, then pull out cable with lever,, then you can remove the cotter pin and disconnect cable from lever but only if you need to replace the shifter cable ,,if not ,, leave it as is , it will be much easier to reinstall
Old Nov 29, 2007 | 11:58 AM
imjrk's Avatar
Thanks, now the next question, all the nuts are off of the exhaust manifold, bolts off the pipe to the cat, but the manifold will not break loose. I have whacked it a few times with a good sized hammer, but I don't want to hit it too hard and crack it. Any suggestions? Thank You
Old Nov 29, 2007 | 12:16 PM
stop hitting it with a hammer,,,,there is a bracket on the manifild held by 2 , 14 mm head bolts, that mounts to the block, you need to remove those , also assuming you got all the nuts from the manifold to head out ,,
but if you are removing the exh manifold , why take the bolts out from pipe at cat?? why not remove the 17 mm head nuts that attach frt pipe to manifold ?? that would be the easiest way
Old Nov 29, 2007 | 02:00 PM
nafango2's Avatar
...are you talking about the downpipe? thats bolted to the engine. remove those bolts and it should just pull down with a small tug.
Old Dec 1, 2007 | 08:17 PM
imjrk's Avatar
I pulled the bolts from the cat because I need to drop the engine/trans to replace the engine. I didn't know that there is an extra bracket on the exhaust manifold. Too accustomed to working on American iron, I guess. My first major project on a Honda and it is NOT going well. Thanks
Old Apr 24, 2013 | 07:23 PM
zorynbebo19's Avatar
Default how do i remove the linkage from a 92 accord?
I can't get the tranny cables off the shifter linkage assembly 5-speed!__
Old Apr 24, 2013 | 07:27 PM
Can sombody help me with some suggestions or diagrams please?
Old Apr 24, 2013 | 07:28 PM
FTPaccord90
Apr 23, 2012 11:26 AM
heathzx
Oct 21, 2011 06:04 PM
mus2fa
Mar 30, 2011 07:03 PM
accordin2u
Nov 3, 2008 09:17 PM
neo123
Nov 10, 2006 07:26 PM
