Accord F20A and F22A engines difference
Old Mar 24, 2008 | 08:07 PM
hawari
Default Accord F20A and F22A engines difference
Hi,
All what I have is an engine with the followings specs: Honda 1997 SOHC 2.0L 16 valves, which is known as F20A Honda engine... I am assuming it came out of an Accord. However, I am finding a hard time matching the parts. I am looking to order spark plug wires and rubber head gasket sealer. I was given F22A as a match, but the dealer was not even sure because I don't have the VIN of the car it came from.
In summary:
F20A has Bore × Stroke: 85.0 × 88.0 mm and Displacement: 1997 cc
F22A has Bore × Stroke: 85.0 × 95.0 mm and Displacement: 2156 cc
Question: Would the two parts I am looking for fit on my F20A engine if taken from a F22A engine?
Old Mar 24, 2008 | 10:28 PM
BlkCurrantKord's Avatar
Default RE: Accord F20A and F22A engines difference
plug wires will fit.
By head gasket sealer do you mean the head gasket? They're both 85mm bore, and I'd assume the oil and coolant passages would line up.
Old Mar 24, 2008 | 10:45 PM
hawari
It's the gasket oil seal rubber.
Old Mar 25, 2008 | 07:52 AM
Oh, then yes it should fit.
ruaphuNZ
Apr 27, 2012 09:39 PM
evader
Sep 17, 2009 03:56 PM
pinecone
Aug 2, 2009 09:47 AM
General
Apr 29, 2008 07:33 PM
bluehonda
Jun 28, 2006 11:38 PM
