accord no spark
Old Sep 15, 2014 | 10:18 PM
lanjeer's Avatar
Default accord no spark
I just finished rebuilding the top end. When i put it all together i tried to start it and no spark it cranks over and all that jazz just doesnt start.. I tested everything in the distributor but no spark. Grounds are good as well. At a loss for why it isnt starting any help is appreciated.
Old Sep 15, 2014 | 10:20 PM
I moved you to here, help will be in here soon..
Old Sep 15, 2014 | 10:24 PM
By the way! What is the year, model engine size and transmission?
Old Sep 16, 2014 | 12:31 AM
lanjeer's Avatar
wow sorry. thats what i get for posting from my phone. Its a 96 accord ex 2.2l 4 cylinder vtec.
Old Sep 16, 2014 | 05:21 PM
lanjeer's Avatar
Anyone got an ideaaarrr?
Old Sep 16, 2014 | 06:40 PM
Check whether you are getting 12V to the distributor connector (blk/yel wire) w/ keyswitch turned to On.
If no voltage, an ignition switch assy fault is likely.
If you have 12V, fault can be ignitor, coil, or perhaps a cracked rotor or distributor cap allowing spark to short to ground.
Check the distributor ground wire connection to the thermostat. It is removed during a head gasket replacement.
Old Sep 18, 2014 | 06:00 PM
Actually the main ground on the 5th gen 4 cyl's is on the drivers end of the TB/plenum.
G101 should be double checked to be sure it is clean and tight.
Also for giggles, what are the colors of the three wires you have connected to the MAP sensor?
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
BostonPuppyDawg
May 27, 2006 02:24 PM
Brian
Apr 5, 2006 02:44 AM
hair ball
Apr 1, 2006 11:56 PM
